Cutting template for smaller laser cutters
If like me you have a small bed printer (in my case 200mm x 150mm) you probably use A4 3mm ply cut to 1/2 size (A5).
To do this quickly with a craft knife I made this template with a slot at the 1/2 way so you can quickly slice on both side of the ply sheets to get exactly A5 each time and then to seal the sheet in half.
Hope it helps - it’s certainly sped up and avoided cutting the sheets ittegularly for me.
