what is the best setting for cutting thru this picture with the 7w pro laser
on a 1.5 mm Basswood
That will depend entirely on the results of your test cuts on the same material, because the cut parameters for a different laser on a different machine with a different material under different conditions will be completely irrelevant.
You can certainly start with whatever settings you’ve found for another thin wood, but expect the unexpected.
If you need help interpreting the results of your test cuts, plenty of folks around here can help with that!
sorry, i forgot to mention that my 7w laser is the J Tech diod laser
