After reading some of these post, it got me wondering if I was really getting the power I was expecting.
I said I could cut 6mm acrylic at 50% power and 20mm/S. Well that 50% power setting was really like 90% of my tube 23mA. From this, I found a few issues. When I last set my power supply I did this by setting it to give 26mA at 99%. So 50% should be around 13mA, but it was 23mA, something not right. Well, I found that my Ruida is only putting out 4.7V, so the PWM is never going to integrate to 5V, or 99% of that. My LPSU uses the same input for analog control and PWM, this tells me it probably has a cheap low pass filter to change the PWM to an analog control voltage. I bet that the analog output of my Ruida controller does the same thing.
So for a while now my power control was very much not linear or anywhere close. I just readjusted my LPSU to give 13mA out when set to 50% power. This gave me just over 25mA at 99%. I can live with that, but I still want to figure out why my controller is only doing 4.7V instead or 5V.
So the reality is I cut 6mm Acrylic at 23mA and 20mm/S. I dropped to 15mm/S and was at 17mA.
So whats the point of this? There was a comment that % power is somewhat irrelevant, which is true. But you might also want to be aware of your tubes rated power vs current and what you are really getting at different power setting. In my case I discovered that something was wrong, what was wrong might explain why I have been having an issue getting grey scale engravings to work well.
Now another issue pops into my head, I need to know how fast the LSPU integrates the PWM, this will dictate an engraving speed limit, but that’s yet another issue.
I hope the OP got their answer, but there were other good thoughts in here.
I have a Boss LS1420 65w and cut 1/2" acrylic in 3 passes running about 9mm/sec at 90% power.
Please note that my first try I used rubbing alcohol to clean the surface after and it caused the acrylic to shatter fracture. Don’t know why but it crackled just sitting on my desk. I figure the alcohol must have reacted with the acrylic.
That it called “Crazing” in the industry, any alcohol, acetone, ammonia based cleaner will cause this. I would suggest using a spay bottle of water with a few drops of dish soap in it.
Just slightly dampen a cotton cloth with it, if it leaves wet streaks you are using to much.
That is how I clean acrylic on a daily basis.
Added note: use compressed air to blow any dust off before you clean, so you don’t scratch the acrylic.
If you go to Edit > Machine Settings, then all the way to the bottom in the Vendor Settings area (unfold it) there’s a section called ‘Laser’ and in there are Min & Max power values. It’s possible that the factory set yours to less than 100% to prevent you from nuking the tube.
That’s not it, laser setup is all good. I looked at the PWM with a scope and all looks well.
In the end, I now have the LPSU adjusted and the laser is working fine, gray scale engravings are now working well with the laser power being more linear.
@NewbDudey. That’s only going to help you monitor your ability to identify if you are overpowering your laser. You still need to be able to identify that your laser is outputting the wattage you’re tube is ratted to output at. The only way to gauge the lasers true output power is by using the device I and @Bonjour suggested you use. This device absorbs the lasers beam and tell you the exact output power of what your laser is emitting.
Compared to the cost of our machines it’s peanuts @Stroonzo.
They do have a great selling point. Warranty replacement if the wattage output is not consistent for the duration of their warranty period. From CO2 manufacturer or machine manufacturer.
I do like the rental option angle. I will definitely do that. After all that business model is COVID19 friendly.
My meter paid for itself whenI ordered a replacement 40W tube for a K40 and the output was 32W (Which I knew it would be) Ebay forced the seller to refund my money for “not as advertised” reasons and let me keep the tube. My little bit of revenge on the shady sellers who over promise and under deliver.
