D1 pro cutting project in small lines
my xtool d1 pro is cutting a project out a little weird < it is cutting the corner radiuses all seperately then going back and cutting the sides of the rectangle , not everything is on one path it seems
who has the fix ?
It sounds like your path sections are not really connected. To confirm, in Lightburn switch from Line to Fill. You must have, in the Window pull-down, selected either Filled/Coarse or Filled/Fine.
If the rectangle does not fill, you do not have all the line segments connected. Use one of the choices for close path or auto-join in the Edit menu. Once the path is closed, you will see the rectangle BOOM!!! (fill) and then you can switch back to Line mode.
