Hi,
since few time I have start a small laser business, I try to develop my engraving skills to be able to give best solutions to customers. I intend to engrave small batches on request and also to give tailored solutions for customers with his own lasers.
At this moment I have a request to engrave text on steel (carbon) and aluminium pieces, as quick as possible at good quality (clean and clear) at 0.2 mm depth, text height 1.5-4-6 mm. Doing some tests to do this I have the impression that the engraving time is limited strong by the material itself, in aluminium I have obtained more easy big depth compared to steel (even if aluminium is declared more difficult to engrave). After a limit, increasing power give only bad quality. I will add some pictures.
Machine fiber galvo JPT 100W MOPA (M6 … I suppose).
My best results obtained for steel with speed 4000mm/s power 75% interval 0,01mm freq 120kHz, qpulse 350ns, 80 pass bidirectional no-cross, increment 3, no wobble; but time is too long compared to expectations. For aluminium I have only decreased the pass to about 35.
results in aluminium
results in steel
I am sure that somebody with more experience in this field can give his advice. Which way should I take for better performance ?
Thank you,
