I’ve been digging around in the config file but couldn’t find where to set the default “open” and “save to” folder. Is there a way to set these?
No - they default to the last place you opened from or saved to.
Any chance to get this feature on the backlog?
The reason… in my workprocess i open files located in my design directory, add customer text to them and save the files in another (customers) director.
I can double check but “Save” and “Load” should already use different folders. Regardless, suggest it on the http://lightburn.fider.io site so it stays tracked. And double check that it’s a LightBurn project, not an imported file - those are tracked differently as well.
I posted the request on fider.io.
Thanks!
