I have an image that I will attach. Is there a way to delete the border so I can do another pass to darken the lettering? The first pass on the border is plenty dark.
HalloâŠ
Anklicken und löschen. Eventuell musst du die Gruppe auflösen
I can delete it with another software, just wondering if I can delete it inside of Lightburn.
select all then ungoup, select only border and press delete
Put the border on a different layer.
I tried, but itâs not allowing me. I bought the file and just went with it. I can âselect allâ but âungroupâ isnât selectable.
post here the project if you can
canât you save and post here the .lbrn2 file? i canât import your pict on LB
If this is a image try tracing it and make it a vector image. Then you can ungroup and assign different layers. If not edit the image to delete the border.
You didnât include enough of your screen for us to see if this is an image or vector source, but based on the way the dotted outline looks, Iâm guessing itâs just an image. You can create a rectangle that covers just the inner portion, assign that rectangle to the T1 or T2 layer (these are tool layers), then select the image and the rectangle, right-click, and choose âApply mask to imageâ.
Vector tracing it would also work, but it tends to lose detail on text.
I appreciate that. Thatâs perfect!
