Is there a way to delete a cut entry without deleting the line. Lets say that I have three lines A, B and C.
I select A and click on red. I then select B and click on blue. Then I select C and click on yellow.
Now I decide that i want to remove the Blue cut but not line B. I see no way to remove the blue cut entry in the cut list.
No - you just assign a different color to the line. As soon as a cut color is no longer assigned to anything it will disappear.
Uncheck ‘output’ on the blue layer, and it won’t run.
I know that Uncheck the output will not cut.
