How is the best way to delete part of a shape? On the attached pic I want delete the upper right corner.
45- picture frame.lbrn (17.5 KB)
Easiest way is to use another shape to “cut” that shape out
Example woudl be, draw a rectangle, Rotate it
Align it
Then use rectangle as a cut shape
Click it - hold shift and click big square
Result will be a line somehting like this
(Note select order matters)
Worked perfect. Thank you, Sir!!
Thank you, Robert, I will give that a try.
If the boolean operations are available, like in @gilaraujo post 2. It will probably do what you want. Since it’s a binary type operation, it’s only available when working with two objects.
The top box was already selected from duplication. Hold control (^) and select other box.
Use boolean subtract (B - A). Selected in reverse order, use A - B.
You can use ^B to bring up the Boolean Assistant window, roll your mouse over them to see the results of different operations…
