Everything was working fine yesterday but this morning updated to version 1.0.04 now in the laser window beside devise says (mirror output) and it does. All the origins are correct in the upper left corner. Origin is moving in reverse also.
Might be a longshot. Is the rotary enabled?
Yes it is! I could try that but even the preview window is mirrored.
There is a mirror output in the rotary setup selection.
Remove mirror in rotary setup took care of that. Now I have to find out if I need to reverse rotary direction next time I use it. Funny everything was fine before the update. Thanks for your response!
