Did Something change or did I change something accidentally?
All of a sudden when hitting the preview button it grabs everything on the workspace. It used to just grab whatever was on the laser grid? Now I have to select “cut selected objects only?” This could get annoying if there are many objects on the workspace..
It has to do with the start from mode you’re using. Absolute coordinates can ignore everything outside the work area if you have “Ignore Out-of-bounds shapes if possible” enabled in settings. User origin and current position ignore the workspace and see everything.
Then I did change something. Thank You!!
