Difference in letters
Why the difference in letters? Same file, same type of wood, Baltic Birch plywood, same speed/power settings. I have the YoraHome 6550-PRO with the 40 watt laser.
The one burn has been sealed however there is a big difference in quality.
Duane
![IMG_0376|375x500].(upload://dhorUbaB3Ejo6SJAyMucaWZ7CtV.jpeg)
By logic it would be due to different quality wood. As you are using the same laser with the same settings, the only variable is the wood. Maybe you even have a sheet that has been surface treated?
two sheets of baltic birch can be VERY different from each other.
Also - I would increase the letter spacing to disconnect the Y from the M :slight_smile:
Thank you Runfel. I wondered about it being the wood after I posted topic. :stuck_out_tongue_winking_eye: The Army is in an image and I don’t think it will let me edit it but I’ll check.
