Hi all,
I wonder if anyone can help me please?
I am having a strange issue with my screw holes on my parts in Lightburn. The round holes should be exactly 5mm diameter and the square holes should be 5.2mm x 5.2mm however I have noticed that the dimensions have changed by themselves slightly on some of the parts e.g., some of the screw hole circles are slightly oval e.g. 5.011 x 5mm and some of the squares are 5.408 x 5.408. It is like a rounding issue with the number after the decimal. It should be .000 not a fraction of a number. The overall part itself seems to have the correct dimensions so it is unlikely I have accidentally changed the dimensions by mistake as they are normally grouped together. My theory is the whole part would be slightly the wrong shape if I had accidentally knocked the dimensions out but it is only the screw holes are slightly inaccurate.
As you can see from the screenshots the dimensions of the screw holes are not locked.
It is strange that the issue only affects some of the holes on some of the parts. If I change them back to the correct value, some update correctly but some do not. I have attached a Lightburn file to show you what I mean. On the bottom part the software will not let me change the screw holes to the correct 5mm x 5mm size. Instead, I get a decimal/fraction each time I try to input 5.0.
I know the dimension error for the screw holes does not matter too much as my laser cutter will not have that level of accuracy anyway, it just seems a bit strange that I am getting this decimal error.
It could be something I have done wrong so sorry if I have made a mistake and caused this myself. I need to upgrade my Lightburn too so maybe it is an error with v0.9.24?
Thank you very much for your help and time.
It is much appreciated.
Rich
LED A2 L5 Frame Parts.lbrn (24.1 KB)
