Dimension Issue
Hi,
I’m experiencing a problem with dimensions. As you can see from the drawings the square is 100x100, and the clock is also 100x100. As you can see the clock
doesn’t fit in the square. Should the two not fit perfectly?
The top images shows the bounding box on the right side does not contact the right side of the clock. This implies that there is an invisible item or an item so small as to be impossible to see (invisible) within the box. Consider to ungroup the clock to determine where the hidden treasure is located, then delete it.
As presented, the clock is smaller than 100 in the x dimension.
