Hello,
I purchased the Lightburn software for a jtech I had last year. I renewed it and I also just bought a CO2 laser and purchased that Upgrade also, My question is this. Does the software let you choose between the 2? or do I have to have 2 different laptops with Lightburn on each?
You can set up as many devices as you want on one copy of LightBurn and choose between them.
Thanks for the quick reply
As Grumpy identifies, you can add all your devices into LightBurn and then pick the one you want to generate the output file for. You do this by adding a new profile clicking the ‘Devices’ button at the bottom-left of the ‘Laser’ window. Once you have configured your devices, you can change the desired output device in the pull-down on the right side of that same window. You can see I have a few setups.
