Hello, I’m a total noob when it comes to engraving.
I’ve had the TTS-20 Pro from twotrees for 2 days.
I have made some tests yesterday, everything worked well.
Today I tried engraving a zippo lighter and I noticed that 0 markings were made at 80% power on the lighter, at first I figured that maybe the material of the lighter is at fault, I tried giving it 100% power anyways. Absolutely 0 markings.
I gave up, I then tried on wood and again 0 markings.
Figured maybe some of the settings in lasergrbl were wrong, I did a fresh reset of everything, still 0 markings. (I tried typing $RST=$, didn’t work, also trieddeleting all files from C:\Users{UserName}\AppData\Roaming\LaserGRBL to get a fresh start)
The machine moves as it’s supposed to, it fires some fainted light when doing so (when it was actually engraving, the beam was more powerful).
Is there any chance that I don’t have a faulty diode?
Everything I find online is about replacing the diode
(Checked all of the cabling, everything is ok, also cleaned the lenses of the diode)
Obviously I don’t know for sure, but I’ve seen several warnings about the reflection from engraving metal burning out the diode. I would recommend reaching out to the manufacturer. You may just have a faulty laser. They should be able to run you through any testing process needed.
That is the first thing you need to do then. Look at the manual, watch youtube videos, whatever, to learn the basic operation of your machine. Many lasers have a flip down leg that you place against the workpiece for focus. Some come wiht a focus block separately that you need to use. You need to understand that before going further. This video shows you how to do a ramp test to find your perfect focus. Often times the focus tool provided with the laser is close but not perfect. Watch some of his other videos to get up to speed on Lightburn and lasers in general.
Let’s look at some basics. Maybe I’ll see something here. Please post a screenshot of your entire Lightburn screen with the Cuts/Layers Panel and Laser Panel visible. Also post a screenshot of the Settings Window (Gears icon) with the Units and Grids tab visible and post a screenshot of the Device Settings Window (Wrench and Screwdriver icon). You can drag and drop the screenshots into your post body.
I think Tim is right here. If the beam is not looking like a clear spot, the optics could be damaged. Usually, you can’t replace the outer lens, since the mirrors or diode itself is damaged. The module needs to be replaced then. But you can do some further check. Show a picture of the wall test (as described here: https://diode-laser-wiki.com/documentation/guide-to-mechanical-adjustments/)
And, another thing to add: this is a LightBurn forum, you seem to be using LaserGRBL, which is not really supported here.
The second piece of glass has either debris underneath or it is burnt, don’t know for sure.
My question is, what is the glass in the second picture, is it the lens or is the lens in the first pic?
I’m tempted to try to take the rubber from the outside of the glass (second pic) and see what’s underneath, maybe change it if that’s the lens, but I want to know if that’s the lens or not
My guess is that that’s the lens, and the first pic is simply some protection, but I might be wrong
The first picture is the protective lens. This one can be replaced and keeps particles away from the second lens (second picture) which is the focussing lens and part of the optical beam forming. If that one is broken, it can’t be replaced usually, because you need a lab to align it properly.
I don’t know if it’s blind, but your test picture looks like 3 of the 4 diodes are dead. You should have 4 lines when you have 4 diodes.
Noobengraver, thank you so much for posting this. I am having the same problem, only I have only tried mine on plywood and paper. At first it burned, and now not a mark at all.
You need to read the manual for the laser.
there is no auto focus, Use the stepped brick to set the focus.
the beam should be 0.4 mm x 0.4 mm dot if I remember.
