im running a longer ray5 20w at 6,000mm/m at 40% power trying to engrave a line but the lines are not connecting its ramping down the power to soon and to much even at 3,000mm/m it gets close but you can still see it not connecting how do i fix my problem even when i cut at 850mm/m at 90% doing 2 passes i get some bad cuts to where it looks like it has dots cut out
Maybe read the documents:
in the link for the corners as far as the settings go it does not say MM/M or MM/Sec for my machine for the settings it is showing in MM/Sec and i did read from head/machine but the numbers are at 500 like the link says
