Hi Everyone. I know LightBurn software can set to disable the Diode Engraver from stopping while its doing engraving when the platform where the machine is mounted on is accidental knocked against. Can anyone advice which fold should I go to to disable this feature. Thank you.
This wouldn’t be a LightBurn setting. Some lasers have shock sensors that do what you’re describing and can be disable in firmware.
What specific laser are you using? Is it the Neje Master 2 in your profile? Can you provide the specific error message that you’re seeing?
Looks like Neje MEMS acceleration detection is only available in Neje mode, not GRBL mode which is what LightBurn uses.
