im guessing bad power supply while running a job without the laser trigger connected it works fine and i decided to hit the laser test button and it shut down again
let me know if you have any other ideas im going to re check all wiring then order a new power supply
as long as i have the laser turned off from any point on off switch disconnecting from board or anything it seems to do everything
i have ordered a new power supply i even disconnected all cables from the cohesion board and hit the test button on the power supply and it still disconnected so we will see what happens next
it should be here Friday
