ehendrix
(Eric Hendrix)
April 1, 2024, 3:30pm
1
Greetings!
This may be a bug or a design issue, I don’t know.
Working on a kerf test card and am getting conflicting views on the screen in LB and preview.
LB Screen view.
And here is the preview screen.
Framing is different for some reason.
Can anyone explain this? If it is a file issue, can you tell me how to fix it?
This is a third party fiel BTW.
ehendrix:
kerf test card
If this is for kerf testing then the difference in view in Preview is likely a result of the kerf settings.
ehendrix
(Eric Hendrix)
April 1, 2024, 3:34pm
3
No kerf settings have been set.
I have made no changes because I haven’t got to that point as of yet.
Why the rounded corners and why is the frame not touching the lines as on the screen as it is meant to be?
You have not set them or no kerf settings are enabled for the layers? I’d suggest explicitly double-checking as that’s the most likely explanation.
If not that, can you share the file for review? If this is a commercial file then send with a direct message.
ehendrix
(Eric Hendrix)
April 1, 2024, 3:39pm
5
OK, now I am confused???
this is a test to find the KERF SIZE. Why would I add a kerf setting that I do not have yet?
ehendrix
(Eric Hendrix)
April 1, 2024, 3:40pm
6
I don’t even know where to look for this kerf setting?
cggorman
(Chris)
April 1, 2024, 3:45pm
7
Kerf offset is in the cut/layer settings. Double click any layer to open settings.
Did you build this file from scratch? If not, it could have almost anything lurking in the dark recesses.
ehendrix
(Eric Hendrix)
April 1, 2024, 4:01pm
8
I re-created the image from scratch and it still the same in preview.
No rounded corners on screen. But it is there in preview.
This is not making any sense?
ehendrix
(Eric Hendrix)
April 1, 2024, 4:05pm
9
OMG…
I just changed the color from the color pallet to BLK #1 from the RED #2 and the preview is correct now.
And I’m really confused now.
Likely because RED #2 has a kerf offset applied at the layer. Double-click the layer settings to confirm.
ehendrix
(Eric Hendrix)
April 1, 2024, 11:59pm
11
Confirmed! You hit it exactly right. Thanks.
system
(system)
Closed
May 1, 2024, 11:59pm
12
