I can not really use your information to find out what is wrong with your svg file. But your screenshot is so large and has a very fine resolution so it is very easy to trace. I know it is not the solution to your problem but in those circumstances it is a quick and acceptable solution, I think.
Have just tried to make a design in Canva`s free version, there are several formats to choose from, but svg is for paying customers only.
Have you really given $ 120 / year for this program? In this case I hope you need that kind of design tool a lot and Canva can get your svg import problem solved. (they should be able to)
Thank you RalphU, that make sense. I hhave tried to import it to InkScape and it imports it as Canva shows, therefore I guess it’s a problem of LB. I’ve tried to export the svg from inkscape to see if it magically solves the problem but still the same. I even tried to export it as an DXF and doesn’t help.
I’ll check your suggestion and see if it traces sharply the jpeg or png.
I donwloaded a PNG (361kb) and since it’s B&G then it traced quite well. Still not sure if it’s worth this money… I’m just not good on graphic design… Anyone knows a better option or software? Thank you everyone!
