I’m having some trouble engraving lately. When I send an image to the laser it display jagged. See attached. I’m using vector files that render fine in LightBurn. It doesn’t seem to matter which vector I send over. The image engrave ok but there are more gaps between the lines than normal. Not a huge amount but enough to make the lines noticeable. I’m not sure when this started. I’m also attaching the LightBurn file I sent to the machine.
The jagged edges are from the scan offset values you have in lightburn. This is so when your engraving at high speeds the alignment is correct when it’s engraving left to right and right to left.
If there is more of a gap between the engraving lines you need to adjust your engraving dpi to a higher number. This typically will vary depending on what material you are engraving on.
