We are having trouble with distortion. The Y axis is elongated and stretched out the image and the X does not. It happened on it’s own…any suggestions why this could happen. We are new to the program and laser. Thanks!
Did you use a rotary last job? If so, then the settings need to be set back to flat work.
Yes we did and I bet that is it! Thanks!!!
I use the rotary, and when I go back to the normal laser I have no problems.
Are the guides smudged with smoke?
Hi GioCad,
I am helping tracyle27 with the laser and I am teaching myself as I go and don’t know all the technical terms for the parts of the laser. what part of the machine are you referring to when you say “guides”?
Tracks, rails …
The rail of the x and y axes
The tracks are clean, and I fixed the issue, the y axis needed to be calibrated.
Thanks for the help!!
