I would like to find a way to change a fill mode into a dither or any image mode without changing the fill from a vector to image.
If I understand the statement correctly you’re saying you want to use image type dithering modes on a vector shape, but without changing the shape into a bitmap. Is this correct?
If so, I don’t believe there’s a way to do this. I suppose you could manually draw tiny vector circles or lines at 100% power.
Is there something specific you’re looking to accomplish?
Yes, you understood correctly! It would save a lot of work if Lightburn would make this possible.
Is there a specific look or effect you’re trying to accomplish? There might be an alternative way of accomplishing what you’re trying to do.
