I recently finished some major upgrades on my OMTech 80-watt CO2 laser and I’m selling the parts I replaced plus some other stuff I had from previous machines.
Specs and pic of the machine I upgraded can be found here.
Lot incudes:
Complete XY gantry set including motors, belts, 25mm mirror mounts and laser head sized for 20mm lens… Profiled linear rails on all axes. External measurements are 1070mm x 810mm. This gantry was functioning perfectly and was removed as an assembly - never been taken apart.
Square steel tube support frame for honeycomb bed - measures 680mm x 1020mm.
Steel honeycomb bed - measures 710mm x 1025mm.
Z-axis lift mechanism - includes screws with sprockets and mounting plates, drive chain, motor with drive sprocket and mounting bracket and stepper driver for motor.
Two identical additional stepper drivers for X and Y axes,
Cloudray adjustable laser tube mounts. Adjustable from 50mm to 80mm tube, microadjustable height and slotted mounting holes for horizontal adjustment.
Second set of Z-axis motion parts (from a previous machine). Includes screws with sprockets and mounting plates, drive chain and motor with drive sprocket.
This is local pickup only, in southwest Missouri, ZIP 65807.
Asking $300 for the lot.
