I have have a issue with the x stepper motor getting hot was wondering if there is any where to change a voltage setting my other DYI laser motor run cool to the touch. Was thinking is there maybe a setting in the GRBL firmware? I will post a link to the control board im running on this DYI setup.
Thanks for any help and tips.
https://www.aliexpress.com/item/32985987910.html?spm=a2g0s.9042311.0.0.1d1b4c4d9G6lCE
Stepper motors by their very nature run hot. The reason it is the X motor getiing the hottest is when you are engraving it is constantly moving, where as the Y motor does very little work. I would not worry about the motor getting hot, it is the way they operate.
True but even when it sitting idle the x is hot and y are cool i even engraved vertically thinking less movement of x but still hot its the sitting idle is what im more concerned about.
Stepper motors have a “hold” when stopped, they resist movement. That also cause them to heat up.
