How do you NOT burn a particular layer?
I have a grid used to alight artwork. I do not wish to waste time traveling over the grid each time and can not figure out how to not cut a particular layer.
You can control the visibility and output for each layer in your project. You can simply un-check the ‘Output’ box next to the layer you do not want output to the laser.
Thank you. I thought I had tried that once before but apparently not. Worked like a charm.
