when i move down the orenge coded fill shape 1mm, cuts as excepted
First change your device to GRBL and not GRBL-M3.
Explain further your issue.
can you explain how to change m-3 to m?
problem solved when i turn of ‘remove overlapping lines’ in optimization settings
but this time it takes more time to finish project
laset does not cut after ‘tabs’
Was on the mobile phone I see now your issue.
Could you post your project .lbrn2 file with the above issue?
