Does lightburn do rapid travel. If so where do I adjust or turn on. what shold the speed be
Click that tool icon for the whitespace scan (rapid travel).
The setting should be what’s best for your machine. If you have a shaky head then the rapid motion might throw off your burn. If your machine isn’t secured to a table top then it could cause too much motion and throw off the burn or move the piece.
Thank you I will try it. My machine is pretty solid, I have small wooden spacers at the corners to hold it from moving
