trying to get the subtraction tools on my lightburn for whatever reason they are not there. i need both of the tools. How can i retrieve them?
You might be missing the tool in the toolbar.
Try clicking on “Window” in the menubar and then select “Reset default layout” to see if that solves the problem.
tried that and nothing new happened… still the same, this is a new computer im using.
I’m not sure what subtract tools are. I can speculate you’re referring to the boolean tools. If so, I suspect you can’t see them because you’re in Beginner Mode. Disable this in Settings.
