Dots when engraving letters coasters co2 laser
Is this a ramp up problem? Seems to burn hot at the start of the lettering. it only happened when it was a certain color or layer?
Try reducing the ‘Min Power’ on the problematic layer - if that’s set too high, it could be leading to the over-burning you’re seeing at Start/End points.
I think I found the problem to the dots while engraving.
Under Cut Settings and then under Advance the Cut thru was turned on.
How it got turned on I am not sure.
Jeff
