And you are da man! On the right track now.
I know this is not the answer you are looking for but give this a try to see if you can work around the problem. Create the job using a VCarve Engraving Tool Path and export the project to an SVG file. Then import the SVG file into LightBurn and see if it corrects the problem. One question I have is does the VCarve Laser add-on support your laser model?
