I have an image that I want to cut so I do a image trace. It produces a double line around everything. How to delete one line? There are some letters involved and when I tried to cut the trace the letters basically fall apart. I only want one line.
The double line problem is related to LightBurn not being able to center trace. With relatively simple shapes, it is easy to delete the unwanted extra lines - after the shapes are ungrouped.
If it doesn’t help, you can post your file here so we can look at the task together.
You can try Inkscape, a free drawing app that works on Win/Mac/Linux. It has a centerline autotrace function that helps with some files.
