Double lines when importing PDF
When I try importing my PDF file from AI, it creates a double line in Lightburn. Is there something I can do on the AI or the Lightburn side of things to avoid this?
Most likely your shapes have a stroke width, and you’re exporting with strokes converted to outlines, or this was something that was drawn in ProCreate or similar, where you’re drawing in pencil / pen with width, instead of drawing simple lines.
You should be able to just import an AI file directly in LightBurn, but to avoid the dual lines I’d need to know more about how the source was created.
I think it’s likely the stroke width. I’ll ask the designer to change it to 1pt and try again. Thanks for your answer. If that doesn’t solve it, I’ll reach out again.
That makes sense. Thank you.
