Hello, recently, I don’t know why, the simple lines, which I use to cut, are done well, but the drawings or the fills, it draws them as doubles, I have investigated and if I deactivate “bi directional scanning” (off) if I it prints well, but it takes twice as long… is there a solution?.. until recently,
I have printed drawings and logos, both in image and fill, and it did it well for me… so I don’t know why now suddenly it doesn’t work correctly for me…
belts and laser are adjusted correctly since I use the motors and structure of my 3d printer, and suddenly, without touching anything, it has started to print that bad…
If that table has valid entries and is enabled, then uploading a screenshot of your design and a photograph of the results will help track down the problem.
I have edited the post to show the result… and no, in the preview you don’t see double lines.
Yes, the double result is obtained when I have bi-directional scanning enabled, what annoys me is that before I had it enabled and the prints came out correctly, and now suddenly they fail…
and I have offset scanning disabled, I had never enabled it.
Well let’s see if I can find time and do the configuration thing, looking at it it makes it make a rectangle with different speeds, but then I don’t know where to put those parameters…
To bad I can remove the bidirectional and it works fine…
What I did was delete the program and configuration, and put it clean,
I put some letters and a rectangle and it records it well in bidirectional, but when I drag an image it’s like the program is misconfigured…
Well, reinstalling and cleaning the entire application, and using other drawings and designs, engraving using the double direction works well for me… I don’t know if it’s an svg file that I made that deconfigured it or something… but the following ones that I have echo did them well for me… mysteries that occur… also the new uses I have not used less than 0.
55 interspacing… which may have influenced having it at .2
