Doubling of size when using PDFs to transfer drawing in Visual Cad 5 to LightBurn
No not solved. Light burn or something else NOT ME is doubling the size of my drawings in Pdf
Doubling of size when using PDFs to transfer drawing in Visual Cadd 5 to light burn. LB doubles the size of the image eactly 2. I was told it was my fault but AI says it is a problem not my fault. Jay
Is it possible to export the design as a DXF file?
DXF is better for mechanical designs, because PDF was created specifically for printed documents.
LightBurn has several settings for DXF import to handle a variety of special cases:
Some tinkering may be required, but DXF will almost certainly produce better results.
I just notice that I can save as a AutoCAD DXF file is available. Did not know it was one of the options. Will give that a try. Thanks
