Hi all,
Is it possible to download design that I made in Lightburn?
Download it that dimensions are the same when printing like that one in design?
Hi all,
Do you want to export your Lightburn design and import it into another program?
Hi RalphU,
No. I just want to print it in the same dimension so that I have template for cutting
Not sure what you mean by “print it in the same dimension”. If you have the dimensions correct in Lightburn, and your laser is setup correctly, it should cut the dimensions correctly
Got to PREVIEW
Select SAVE IMAGE
