Downloading project it cuts reversed
When I insert a project into light burn it looks correct, but when I go to do the burn, the project is backwards and upside down…is it the software or the controller…
I have a new K40 40w machine and useing lightburn software…PLEASE HELP
Which controller board are you using? Most likely you have the device origin set to the wrong corner.
i use the cohesion3d and smoothie firm ware
Go to Edit > Device Settings and make sure the Origin corner is set to bottom left.
Oz nailed it but I just wanted to add that there is a walk through video on job and machine origin that may help you out.
