I have watch numerous videos about DPI setting when setting up to do a job. Iam currently running1.3.00 and cannot find the drop-down box I have looked in setting and cannot find it. Can someone please assist me
For each fill layer there is a Line Interval/DPI setting. Just open the Cut Settings for that layer.
Hi Clark, OK thanks the video’s I have watched had a specific DPI box but checking mine it shows line /interval and underneath lines/inch. When I adjust the lines /interval it automatically adjusts the lines/inch. Thanks for your help in clearing this question up. David
You are correct, the Line Interval and Lines per Inch are tied together. They are just different ways to represent the same thing. 500 Lines per Inch is equal to lines being .051 mm apart from each other. When you change one, it changes the other.
Hi Steve, thanks for your comments and screen shot. It only confirms and clarifies what Clark had said but also makes it clear in my mind it by the graphic.
