I did some searches but didn’t see any definite answer.
I see all the time posts about whether to open or import vs drag and drop. I normally just drag and drop. I have tried on a couple of files to do each (open /import/drag and drop )and see if there were differences and I couldn’t see any in the way they opened or in the settings. They all seem to change the settings I have for each palette color. I mean i have 01 black as 10/48 but if the file is different it changes it to whatever I guess the designer saved them as in their LB regardless how I bring into LB.
I also so a post saying the dragging and dropping could also make other changes to LB other than just the layer settings. It was said like that device/machine settings could be changed if you dragged and dropped instead of importing. Is that possible ? I don’t think so but I’m not expert and just barely knowledgeable with LB.
So is there really any differences in way brought into LB and does the format matter in those ways too (svg/lbrn2/lbrn/dxf/pdf etc)
Can just draggng and dropping make changes to the LB device/machine settings ?
Thanks for the knowledge.
