Draw lines angle, concentricity
Hello Everybody,
I don’t know how to set up the tool
Draw lines (Ctrl+L)
so I can simply draw lines at some angle, option snapping 90,60,45 degrees, concentration, etc.
It is possible?
(Maybe this is a stupid question? I’m new to LB even though I’ve owned it longer :thinking:)
Hope right category here?
There is an option for doing 45º increments. Check out this short video for a better explanation.
Hope this helps.
:smiley:
If you click the draw lines tool and press Shift you can start drawing a line at 0º 45º and 90º.
After you can select the line/shape and rotate:
  • CW = press “.
  • CCW = press “,
  • . (,) = 90º
  • Shift + . (,) = 45º
  • Ctrl + . (,) = 15º
  • Ctrl + Shift + . (,) = 1.5º
    You can also select your line/shape and rotate to any value:
Looks interesting, I must check
Thank you!
Looks interesting, I must check too
Thank you!
But do you understand what I mean with simple angel setting and with snapping?
And usually some other curve sw
offer different options for drawing lines such as parallel, centered or 1/2, 1/4, 1/3
