Hi,
How do you draw straight lines of specific length? Struggling to do this and there must be an easy way? Any suggestions greatly appreciated.
You can do it the same way as for example a square, draw an unspecified line, horizontal or vertical, then you determine the length up in the menu list X/Y. It’s a bit “reverse” CAD
, but it works quite nicely.
Ps. hold down the shift key while drawing the line, so it will be straight.
Thank you - will give this a try ![]()
