Driver installation
I need help with LightBurn driver installation.
I am using both Ezcad2 and LightBurn programs. I was always able to install the LightBurn driver using the ZADIG program. However, I have deleted some files from my computer during a disk clean-up and ZADIG is no longer working. Freezes as soon as I click on “List all devices” I have tried to delete it and reinstall it several times with the same result.
My question is:
How do I install the LightBurn driver without using ZADIG???
Thank you in anticipation…
Brian
Maybe reinstall Lightburn. Will install EZCAD driver if box checked?
Thank you for responding. I did reinstall LB but that has not helped. What happens is that when I start my Laser it opens the Ecad2 driver unless I was using LB when I shut my computer down. So, from LB to swap back to Ezcag2 I must delete the LB driver and restart Ezcad2. When i work the other way round i.e. swap from Ezcad2 back to LB I use the ZADIG program to replace the Ezcad2 driver. … I hope that makes sense. Now my ZADIG program is freezing all the time, so I must find a separate way to reinstall the LB driver.
Brian
Ah, So there are bright people here that can surely sort that out.
Maybe download ZADIG and install again https://zadig.akeo.ie/
Fernando
Edit: sorry I only noticed on the second reading that you had already reinstalled several times.
We have specific guidance here: Galvo Installation - LightBurn Software Documentation
