Hello
I change today Leetro to Ruidia on my laser cutter
I have not cut trough lines in my project.
Looks like driver slowly decrease power on end of line and slowly increase power on beginning.
Ewen if min and max power is set to 45% its happens.
I made gaps between lines 0,3-0,4mm as bridges in project.
Start and end delay is set to 0ms
If the layer speed falls below the controller’s Start Speed, the power will behave as you describe. Check Edit → Machine Settings to find the Start Speed.
However, the machine acceleration may also be set very low, so that the machine spends too much time speeding up and slowing down along each vector. There are several acceleration settings scattered through the Machine Settings: my machine has all of them around 3000 - 5000 mm/s², so if your machine is set much lower, than can be part of the problem.
I believe that setting determines the turn-on and turn-off delay for the vent fan or assist air output signal during the whole job.
The start speed is set to 20mm/s i check it in User setings
Work sped 45mm/s power 50% laser is RF synrad Evo 125
I still use RDWorks because I dont set up Lightburn for machine.
Its crazy because if I have circle is cut perfectly first one (1)
But after add 6 bridges by 0,4mm the driver starts getting problems with cutting.
So cuts in first row 2 3 and 4 are with bridges
Second row is wit trough mode setting power 50% delay 120ms 60ms and 10ms
