Dual laser setup
Hello people new to the forum thanks for any assistance in advance. I have a dual laser setup 130/40 w Co2 jobby. I am setting up a job for when I get home ( I work away) and am experiencing difficulty getting the cut and engrave settings to indicate correctly on the CUTS/LAYERS tab.
I can double click on the “Engrave” layer and select Laser 1 but it also seems to change the other “Cut” layer to Laser 1 when I want it to remain on Laser 2. Also works the other way if Laser 2 is selected. Is this possibly because I am not connected to the machine ?
I just tested this quickly to make sure it was working as expected, and didn’t see an issue.
Here’s what I did:
dual
If you’re doing the same but seeing a different result, please share the file you’re working with, so we can take a closer look.
Thanks for the reply so its an issue with the indication on the cuts and layers faceplate by the look then. I will just ignore it then and rely upon the editor faceplate to be the one I trust. Thanks for the reply
