DXF curve error in versions 1.1.00 and later
We have been using v1.0.06 for some time and once we recently upgraded to 1.1.04 we had issues with a curve we use for marking pieces by scoring the material. The single curve makes the number eight. An image below shows the error in the line. It only happens on this one curve, and after uninstalling and reinstalling previous versions, found that the issue started after v1.0.06 when v1.1.00 began.
Can continue with the old versions, but wondering if there is a fix for me or to be expected in future versions.
DXF sample
Capture
I;ve also had this happen.
I’ve solved it by resaving the DXF again from CAD.
Also make sure the shape is fully exploded before you save it, for some reason grouped or complex shapes that are still combined give me an error also.
good luck
_8-1.dxf (110.7 KB)
I looked at your file, convert the spline to a Polyline and resave then it works fine.
I attach it for you
