I export a drawing from coreldraw to lightburn but it imports really small like 20mm
What file format are you using to export from Corel? What units are you using when creating this file within Corel?
it was a .dxf format
Have a look at the ‘Settings’ page (click the “gears” icon to expose) to ensure you are using the same units used when you created your art.
That did the job thanks.
I edited the title to help others searching for similar issues. If you would please, mark this post as “Solved”. To do so, click the 3 dots at the bottom of each post, then click the gray checkbox.
