I updated to v1.7.07 and now when I open a dxf file it looks like this? How do I get rid of all those lines?
I don’t know - I didn’t make the file - just uploaded it. After further investigating, it appears that this was one of the files that was originally an stl file that I converted to dxf using FIleFormat online converter. And apparently Fusion 360 files had some issues with Lightburn awhile back? Maybe this was originally a Fusion file? All other (nonconverted) dxf files load normally. At any rate, the fix I found was to simply use the select tool and drag from right to left to get the green box (not the red one left to right) and select large sections of lines at a time and hit delete. Takes a little time but it works for a workaround at least if that helps anyone else…
