Easy and fast material/speed test
To find the right settings, I like to use a small test to find the appropriate power and speed settings.
It also shows where the limits of the speed lie.
Picture is before I remove the dust from engraving.
The material is 2-layer sign material, (ABS), 1.6mm, I use 11.5% power max, 8.5% min, 0.07mm line spacing. (the process can be optimized by increasing the line spacing and fine-tuning the power settings)
I choose 300mm/s, because it is the fastest with not too deep engraving and which gives the nicest result under a magnifying glass.
The interesting thing is, however, that the process time increases from 300mm/s, i.e. higher speeds do not necessarily give better process times. :wink: (It is important to find/know the limitations of your machine.)
I like the idea of testing fonts and not just boxes.
Why don’t you share your .lbrn test file, so new folks can better understand how you designed it?
For users not familiar with material tests, LightBurn has one built in too:
I didn’t expect there to be any use/interest in the test itself, because it is relatively machine-dependent. (CO2 60Watt) It was mostly the speed curve I was interested in.
But of course everyone is welcome to use it, just remember to adapt it to your machines/material.
I have read the real times from the controller after each test/speed and added them manually.
Notice that there is very little deviation from LB’s calculated times to the actual measurements, some are only a few ms off but rounded up.
ABS-Sign Test.lbrn2 (218.6 KB)
