Patledoc
(Patrick PARENT)
June 21, 2023, 7:39am
1
Le laser refuse toute connection, que ce soit USB ou Ethernet.il affiche systématiquement la machine est peut-être occupée soit en pause.
The laser refuses any connection, whether USB or Ethernet. It systematically displays the machine may be busy or paused.
JohnJohn
(John Johnson)
June 21, 2023, 10:07am
2
How have you chosen to connect with the Engraver?
You may find more stable communication by running ethernet from the engraver to your router, switch or ‘firewall’.
If you are communicating directly through the USB port, the HP Computer may need the FTDI driver.
https://ftdichip.com/drivers/d2xx-drivers/
Patledoc
(Patrick PARENT)
June 21, 2023, 12:18pm
3
I use a Laptop and connect it directly to the engraver.
It used to work with the USB cable but doesn’t work anymore. It says that the engraver is already busy or in pause.
It send the same message when connected with the ethernet port
system
(system)
Closed
July 21, 2023, 12:19pm
4
